Home › Forums › Discussions › VinFast VF8 critical errors
03/03/2024 at 06:44Other day, newley leased VF8 start throwing up bunch of critical errors related to all functions(see attched). These went away after I locked and came back after 5 min. After all this and other issues related to saving drive mode settings, backup camera not showing guide lines, and few other, I’m concerned about VF8 being road safe and having second thoughts of jut biting the bullet and return VF8. Wish Vinfast has policy of just returning the vehicle
Thank you for your feedback. VinFast sincerely apologizes for the experience you had on the VF 8. The VinFast team will contact you as soon as possible to solve these problems.
No one from Vinfast has reached out to me yet on this issue and other issues that I have posted. Some customers might be getting preferential treatment. How can I escalate this
This reply was modified 2 years, 7 months ago by
mswaraich.
Currently you cannot save the drive mode setting. They will fix it in the next sw update,
For backup camera not show the guide line, after you step on the brake to start the car, you need to wait for the “camera” icon at the left bot corner to not be grey out then it mean your backup camera has finished booting up.
Other warning could be just the glitch from the 1st time, and they should all go away
Thanks and really appreciate it. I will give it a try.
VinFast service did reach out to me and has setup service call. Really appreciate it and happy with customer support
mswaraich.
A software updated release is definitely due. I am also seeing bunch of issues which have been happening frequently but go away after you lock and come back.
Were they able to fix it for you or we need to wait for software update?
Have you checked your 12v battery? If 12v is below 65, it usually gives out bunch of errors.
Here is how to check 12v battery https://youtu.be/55bCsg-9H8M?si=qZy-d3jYeBM0_zwwhttps://youtu.be/55bCsg-9H8M?si=qZy-d3jYeBM0_zww
I get a lot of errors on this car as well and VinFast does not want to take it back. I do not drive this with my family in it. Just waiting for the day something happens when I am in this car. Like the lane assist that doesnt work well.
