Home › Forums › Battery & Charging › Can I use VinFast app to charge another EV?
  • Can I use VinFast app to charge another EV?
    12/10/2023 at 17:53
    Let’s find out if we can charge another EV via VinFast app
    This is especially helpful if you need to rescue someone you know at a charging station or just for fun in general.
    Can I use VF app to charge Volkswagen ID.4? – YouTube
    6
  • Yossi Gordon
    03/28/2024 at 23:48
    I used my Vinfast app to Initiate a charge for my loaner car. Instead of going to the charging section, go to the map section, and you can select the charger from there. it will ask you the stall, and let you start.
      05/14/2024 at 14:01
      Yes the same method applies for charging loaner. As long as you can locate where you are, you’ll be able to initiate charging session via vf app.
  • Hoa Nguyen
    12/12/2023 at 10:24
    I tried to charge a VF8 loaner car at EVGO, but it didn’t work.
    12/11/2023 at 07:48
    P/S: we only have 3,460kw of free charge. Use it wisely 😝
