Home › Forums › Discussions › Wishlist for VF8
  • Wishlist for VF8
    08/02/2023 at 02:18
    Hi guys
    We have a small FB group for VF owners called VinFast Friend Support. We put together a list of future enhancements for VF8s:
    -Battery Temperature shows on mobile app
    -Sentry mode
    -A way to turn off car like regular ICE cars (currently you need to lock the car to turn it off) >< A way to just unlock the car without turning on car’s computer if you just need to put something in the car or install car seats 😀
    -Turn indicator show on HUB as as well dashboard
    -Schedule charging capability (to take advantage of TOU electricity pricing)
    -A way to reset car computer (like Ctrl+Alt+Del in PC). The volume button doesnt completely reset the car computer.
    Feel free to add more to this list. Thank you
Page 1 of 2
  • tuan le
    10/09/2024 at 19:04
    I agree with the ON/OFF wish. I have a 2024 VF8 Plus – one-week old. I wish for no delay in acceleration. The car gave me a heart attack when I stepped on the pedal at the light merging onto the freeway and the car hesitated for half a second. Other than that the car is great! YouTube is full of distorted information. I joined the Vinfast Fan Support Group but awaiting approval. Anyone knows how long?
  • Charles Winham
    10/08/2024 at 15:01
    Alexa advertises that it can operate smart home devices but I get a message that only licensed Alexas can perform that function
      10/17/2025 at 00:11
      it did happen to me, but after a few sw update. i can now command Alexa to open/close garage door, turn on/off lights in the house etc.
  • Charles Winham
    10/08/2024 at 15:00
    Outside temperature display
    Ability to use delayed charging (some of the cheaper Level 2 chargers allow you delay charging up to 12 hours) to take advantage of TOU savings
      10/17/2025 at 00:10
      these 2 are already a feature on new fw with new UI 8a.3.11.0 and up
  • Troung Cao
    10/08/2024 at 11:44
    It’s been almost 4 days, and My post hasn’t shown up.
    Has anyone else had issues with the car autosteering in the wrong direction?
    My Post that is still under moderation review”
    Today while merging onto the highway, there was a split to go left towards highway, right towards surface streets. I have taken this route with the car about 4 times prior without issue. Today for some reason it beeped and jerked the car severely to the left and I had to fight the wheel pretty hard. If the card had its way I would have gone down the ditch. How do I pull data logs to make a complaint to NHTSA? Happened on 10/4 around 8am PST. “
    • Charles Winham
      10/08/2024 at 15:02
      I had the same issue, I turned off the lane keeping function and that solved this issue – OTW, it’s dangerous!
      • Troung Cao
        10/16/2024 at 09:05
        Today the car was full of malfunction alerts. While driving straight on 101 soutbound centered in marked lanes, the car alerts went off and it tried to veer right to the next lane. There was no reason for this. I just so happened to be on the phone with customer service. There are definitely issues with the systems.
    • James Herrera
      09/01/2025 at 12:33
      I have recently experienced similar situations with merging lanes or on ramps but last night for no reason at all the vehicle aggressively jerked the wheel to the right. I was driving on the interstate in the far right lane with a sound barrier wall on the right. Separately last night while going down a level city street abruptly braked. Both instances there were no alerts or warnings. Concerning since I almost always have the ADAS activated.
  • Troung Cao
    10/04/2024 at 13:47
    Fix the Blinkers
    and Fix the slow charging after 70%. Other EV’s allow fast charge up to 80% SoC then slow down. That 10% with the limited range already makes a big difference.
  • Sean Kirby
    09/13/2024 at 11:29
    A sound system software update to allow more control…The equalizer is not sensitive enough and always biases Highs and lows…no midrange….Too much reverb. Or Surround sound in the plus. I am happy with the car overall…and I had better sounding sound system in every car I have owned since the 90’s …..second annoyance arebthe blinkers….frustrating at times to turn off …and the need for a page showing how efficient you are driving..
    • Troung Cao
      10/04/2024 at 13:08
      Blinker Cancel button doesn’t even work, so why offer it? They need to change the blinker stock and functionality. I drive around looking like a 90yr old cause I can’t get the blinkers to turn off.
    • Brian Tunget
      12/14/2024 at 06:06
      My BMW M Roadster had a legendary bad stereo. My GLB was also horrible. On the other side, my SLK is awesome.
      In comparison, I find the VF8 to be pretty good with some manipulation of the EQ settings.
      My custom settings work good for most music. This is with full focus which gives a surround type of effect.
      My reference for this is TOOL – ‘The Pot’ which places the first rototom hits behind your head.
      Anyway, try these.
      You may wish to lower the 250 Hz a notch or 2. This adds a little drive for most music but also muddies the sound a bit.
      I don’t recommend the bass above this. It will add that bass bias that we all know from any rental vehicle that a young person rented. There is more than enough bass here and most likely still above where it was monitored in the studio.
      If you want clearer sound, focus on the front seats. Full focus, gives a fuller sound but does add a bit of bass bias.
  • Carl Dziuk
    07/31/2024 at 20:20
    – garage door operation – from the console
    – better feel from the accelerator – right now i press it pretty far from a stop and there’s little response. It should be more sensitive
  • Adam Storek
    07/22/2024 at 16:14
    There needs to be a way to save preferences for driving features. The drive mode, regen braking, driver monitoring settings etc. seems like an easy add…
  • Brian Tickenoff
    05/22/2024 at 11:00
    Interior cabin lights are VERY weak. May as well not even have anything there.
    More lights in the trunk area. It’s quite dim in that area at night.
    Save the “drive mode” after returning to the vehicle (I like “eco” but it always reverts to “normal”
    Interior cabin noise is pretty loud compared to other EV’s
    The sound system is quite lackluster on the Plus. For a “premium” vehicle, I expect much better.
    No HomeLink remote control for garage doors/gates.
    When the radio is on, I wish it’d display the channel info/song playing like just about every other car currently on the market.
  • hec luis
    02/21/2024 at 19:20
    I just got VF* great Lease
    BUT I CANT find an insurance company to insure it …
    Very hard
    . also car t rolls backwards in a hill when i release brake to accelerate
    Problematic
      02/22/2024 at 05:53
      I have wawanesa for both of my vf8s: 1 with SDI battery (City Edition) and 1 with CATL battery (Standard Edition). Other owners have coverage via farmers, century etc.
      Try setting your car to Creep on, it wont roll back. Vf8 doesnt truly have auto-hold mode but that’s 1 way to get around it.
      If your drive mode is on Eco, you definitely feel the roll-back. If you’re on Sport, you dont feel as much.
      Another scoop is, my 1st vf8-the sdi’s hill assist is not as stable as my new vf8-the catl.
      I do have hopes they’ll address this issue in future updates.
      Also, if you have Facebook, come join us on “VinFast Friend Support.”
Page 1 of 2
