Home › Forums › Discussions › VF8 Drive Aids no longer available
  • VF8 Drive Aids no longer available
    03/05/2024 at 10:47
    I cannot access Drive Aids as of this morning. Any help? And also rear back up camera does not show steering guidelines after vehicle has sitting idle for long time esp in mornings. 360 camera on turn signals works intermittently. Reached out to service but not able to get appoinment before 3 weeks. If it is software issue then I believe it can be addressed remotely.
    another issue: I plugged in VF8 for charging and locked it. Now VinFast app shows” No valid key found in Car”
  • Maninder Waraich
    03/06/2024 at 20:32
    VINFAST Technician after trying everything ended up resetting the vehicle to factory reset which resolve the issue but now front collission detection is not working. It is raining and front collision detetction off message popping up on screen. ANy help on this
    • Phuong Pham
      03/07/2024 at 10:06
      Front collision work depends on the lidar in front of the vehicle. The lidar will not work reliably when there is heavy rain due to the reflection of the light can be impact by the water. Therefore, it is safer to let the user to handle such situation.
      What is lidar? Learn How Lidar Works | Velodyne Lidar
