Home › Forums › Discussions › Steering wheel will no longer adjust? Other topics
10/17/2024 at 20:09Hello all I’ve had my VF8 for 3 weeks now and on week 2 my steering wheel adjustment will no longer work. Not sure if the motor failed or a fuse failed. Anyways the steering wheel is all the way in. Has anyone else had or has this issue? Lastly when I received my VF8 I noticed when I center my steering wheel while driving vehicle veers left. The steering wheel is not centered. Though these are minor issues, they are still issues and hope I can get this repaired timely. Also I’ve been looking to see what the latest software version may be? I’m sure I’m on the latest but figured I ask. As a lot of the safety features in the Drive aids don’t save still and I have to adjust every time I get in the vehicle.
Try this https://youtu.be/tg0ueCUV9oM?si=VK7XUXAU0OgEuap0https://youtu.be/tg0ueCUV9oM?si=VK7XUXAU0OgEuap0
Thank you Natalie, this fixed it for me very easy!
I have the same issue. The steering wheel adjustment does not function anymore. I will try to reset it and check the fuse. Thank you for the video.
Second time it stopped working for me but resetting by disconnecting worked. Hard to squeeze my hand in there though.
