Home Forums Battery & Charging Slow Charging Vf8 2025
  • Slow Charging Vf8 2025
    10/28/2025 at 22:21
    I had my car less than a week, when I tried charging at Chargepoint station lv2 charger it took 3hrs 55 minutes to charge from 17% to 26% which is very bad and have to pay hourly charge rate.
    I also tried at my friends home with j1772 lv2 charger and does the same. It says 22 hrs to fully charge from 22%
    Vinfast says 6 hrs to fully charge with lv2 charger but this is not even close. Does anyone have similar issue. I would regret very bad leasing if this is expected
    10/29/2025 at 04:48
    on your vinfast screen- go into settings — EV –>> Settings and adjust your AMPS! – I have an lv2 J1772 in my garage – from 20-100% takes about 7 hours – AVG 9KW an hour.
    11/12/2025 at 18:20
    Once you plug in, tap on battery icon then tap on gear icon to adjust your amperage.
    I suspect your amperage was very low. At 32A, you should be able to get about 7% per hour.
