Home Charging MUST!
If you have not started using the included at home charger I would recommend it!
Using the standard 3 prong charger (<g-bubble jscontroller=”QVaUhf” data-ci=”” data-du=”200″ data-tp=”5″ jsaction=”R9S7w:VqIRre;” jsshadow=”” __is_owner=”true”>NEMA</g-bubble> 5-15P) gets a full charge to 90% in about 72hours from 30%.
But recently I got an adapter for my washer/dryer and this thing will charge the car in 5 hours to 90%. I would highly recommend it as it is cheaper than charging at the stations. This is about $12 for me in my location compared to $40 at the stations.
Link to my adapter, but check what kind of plug you have. If you have a picture of yours I can try to help you find an adapter! CHEERS!
LINK: https://www.amazon.com/gp/product/B097M95SWY/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&th=1&_encoding=UTF8&tag=itssjustej-20&linkCode=ur2&linkId=d02ff59683283276f0de331aa258193d&camp=1789&creative=9325“>NEMA 10-30P to 14-50R EV Charger Adapter Cord
