Home › Forums › Battery & Charging › Charging VF8
  • Charging VF8
    06/25/2024 at 11:20
    I have not been able to get my VF8 to charge any higer than 40 amps on a 48 amp charger. Anyone have any ideas?
    05/20/2025 at 10:31
    If your using a plug and not directly wired into the breaker – then this is how its suppose to work! you only can get 40A out of a wall plug. If you want the full 48A you will need to have the electrican wire it directly into the fuse box and bypass the outlet.
  • Elvis Leon-Avila
    09/22/2024 at 23:55
    Also check your 48amp charger. Maybe the installer didn’t change the dial to accept full 48amp. Verify by checking your breaker is a 60amp also
  • Manny Boulos
    09/19/2024 at 22:02
    did you go into the settings and increase the charge rate. Its under the battery monitor and is looks blanked out and has a – and +. I didnt know about that until I called tech support regarding slow charging with the stock charger. Maybe that will work for you too.
