Home › Forums › Battery & Charging › Charging VF8
Charging VF8
06/25/2024 at 11:20I have not been able to get my VF8 to charge any higer than 40 amps on a 48 amp charger. Anyone have any ideas?
did you go into the settings and increase the charge rate. Its under the battery monitor and is looks blanked out and has a – and +. I didnt know about that until I called tech support regarding slow charging with the stock charger. Maybe that will work for you too.
Also check your 48amp charger. Maybe the installer didn’t change the dial to accept full 48amp. Verify by checking your breaker is a 60amp also
If your using a plug and not directly wired into the breaker – then this is how its suppose to work! you only can get 40A out of a wall plug. If you want the full 48A you will need to have the electrican wire it directly into the fuse box and bypass the outlet.
