Home › Forums › Battery & Charging › Charging Issues
  • Charging Issues
    04/19/2023 at 09:16
    Has anyone experienced charging issues? I was never able to charge using the issued level 1 charger. I just recently installed a level 2 charger. It worked 1 time, but now the on light turns yellow and it turns off. It’s very frustrating to say the least. I have an Autel MaxiCharge. I’m pretty sure they’re the same supplier for the VinFast level 2 charger.
    23
Page 1 of 2
  • mark mizrahi
    01/07/2025 at 05:26
    Vinfast lied to me and said December 2024 there would be a new update to resolve the charging problem my car even when left at level two stations the car will stop charging because of a dip in energy for a second. I cannot use my car for work anymore cause it takes 20 hours to charge my car at 19 amps which is what they said I have to charge it at this is ridiculous. I will say they smile and sound nice in the phone that’s pretty much it in terms of helpfulness need a good lemon attorney. Unhappy customer will not recommend if this simple simple software issue isn’t rectified
  • Troung Cao
    10/04/2024 at 12:27
    I’ve had it start to charge and then stop and give me a warning the charger door was open. had to go back unlock the car, unplug and re-plug it in.
  • Fabrice Sopoglian
    10/03/2024 at 01:21
    Hi,
    I just got my Vin Fast few days ago! I have a Tesla home charger at home! I am using an adapter to charge but my circuit breaker of my panel keep on disconnecting after 10 minutes while using my Tesla charger with the adapter, I am using an adapter J1772. It’s only charging for 5/10 minutes and then my circuit breaker keep on tripping while charging my Vinfast and the charger stopped! Could you please give me some options? Thanks
  • Angela Carter
    07/25/2024 at 10:19
    Mine works overnight with my issued level 1 charger
  • Tin Pham
    07/24/2024 at 09:05
    Same here. I tried to called the number they provide but they just said call the dealership. I lives in Jacksonville, FL and the closest one is 1.5 hours from me. I don’t know why they provide the phone number but can’t do anything but ask me to call the dealership. Very disappointed.
  • Dale Sharp
    05/06/2024 at 03:27
    Similar problems, sometimes the car will only charge 10 or 20% then stops charging for no reason. It doesn’t matter if I use level one or level two charger. It doesn’t matter what time of the day or night it is, though I do prefer to charge during the off peak electrical hours of 10 PM to 5 AM
  • Jake Storms
    03/09/2024 at 20:50
    Been having random charging issues also. Just got the car on the lease deal a few weeks ago. Can usually get it to charge level 2 at 30amps. But often disconnects and stops charging leaving the provided mobile charger with an orange light. Have unplug it and then replug it to car and it starts again. Usually will go ahead and charge to the 80-90%, but often have to go restart the charge 2-4 times before it finally just keeps going. Luckily the app normally drops notifications that charging completes well before I am expecting it to so I can go get the thing restarted…but becoming pretty annoying.
  • Stephen Clarke
    07/28/2023 at 09:19
    I had an issue using my juice box level 2 40amp charger. I could not get the vehicle to take more than 15 amps. I used the suppled charger with the 220 plug and it charged fine. Unfortunately after charging my VF8 had some issues.
  • Phan Trinh
    07/18/2023 at 01:42
    The Vinfast Home charger is not working right when you charge at home. You should buy Autel home charger .
    They work perfect for me
  • George Sami
    05/09/2023 at 13:01
    I just received delivery on Sunday, 5/7. I tried charging for the first time last night using a level II charger that I know for certain works because I charged my wife’s EV earlier in the day and it charged just fine. I plugged in my level II charger at night and the battery was at 46%. The car charged over night. When I woke up today, I was shocked and upset to find that the car charged only 4% (it got to 50%) after 8 hours of charging. The 8 hours of level II charging should have fully charged the car. And, the Vinfast charge port light was flashing green when I plugged in, meaning there were no issues. Has anyone else experienced the same issue How? How am I supposed to use an EV car ( that I need to go to and from work!) that charges at this ridiculously slow rate?! I called customer service this morning and I was told the Service Center will call me to schedule a time to bring it in. So far, this has been a very bad first impression, Vinfast! I hope you turn it around quickly, or you won’t survive. I too share the frustration of other members on this forum.
    • VF Staff 8
      05/09/2023 at 16:39
      Hi Mr. George Sami, thank you very much for using VinFast vehicle. First, we are very sorry to hear about the charging issues you are having with the car. All of your concerns have been well-received and forwarded to our technician team for further inspection. Our technician has also reached out to you and left a voice message to schedule a mobile visit. For any further updates on the progress, we will contact and discuss with you in person then, Sir. Once again, we do understand your irritation as for a new vehicle, and sincerely apologize for all the inconvenience it may cause. We will follow your case attentively and do everything we can to resolve the problems at the soonest. Please feel free to contact us at 1-833-503-0600 if you still have any questions, we will be more than happy to assist. Thank you very much!
    • Chris Gerrick
      11/10/2023 at 11:35
      We have tried 3 different Level 2 chargers and none of them will charge the VF8. They all charge my Tesla though without issue and at the same speeds. So we returned the chargers and are again using the VinFast Level 2 charger for both VinFast and the Tesla. Tesla charges just fine at 32 amps but the VinFast will only charge at 18 amps. The charging cannot keep pace with basic daily driving.
Page 1 of 2
