Home › Forums › Discussions › Camera 360
  • Camera 360
    03/03/2024 at 00:44
    Camera 360 option doesn’t work on VF8. It doesn’t turn on camera 360 even speed under 9 mph or make a left turn. Need help! Thanks
  • prvin t
    03/17/2024 at 22:58
    I too facing same issue? it does’t turn ON while taking turns .. Is there any fix for this issue?
      03/23/2024 at 14:59
      While taking turns? Hmmm
      There’s a setting in Drive Aids that has to be on. If it’s on while at a stop or less than 9mph, camera will be on.
  • Tho Nguyen
    03/04/2024 at 09:07
    Thanks Vinfast for quick response. They sent a tech to explain my problem and it took care the problem👍❤️
    • Maninder Waraich
      03/04/2024 at 09:15
      What was the solution? I ‘m having same problem
      • Phuong Pham
        03/04/2024 at 21:35
        The setting wont save, every time you turn on the car, you need to turn on that feature again
  • Tho Nguyen
    03/03/2024 at 22:05
    It is very important safety feature. It helps to reduce blind spot when you make change lane. I hope next software update will fix it 🙏👍
    • This reply was modified 2 years, 8 months ago by  Tho Nguyen.
  • VF Staff 5
    03/03/2024 at 06:50
    Thank you for your feedback. VinFast sincerely apologizes for the experience you had on the VF 8. The VinFast team will contact you as soon as possible to solve this problem.
  • Maninder Waraich
    03/03/2024 at 06:18
    Same here, Sometimes it workd while other times, it does not.
    • ted pan
      03/04/2024 at 23:17
      People on facebook indicated you need wait for system fully started up before doing anything. It’s about 2 mins
