Home › Forums › Discussions › Camera 360
Camera 360
03/03/2024 at 00:44Camera 360 option doesn’t work on VF8. It doesn’t turn on camera 360 even speed under 9 mph or make a left turn. Need help! Thanks
Same here, Sometimes it workd while other times, it does not.
People on facebook indicated you need wait for system fully started up before doing anything. It’s about 2 mins
Thank you for your feedback. VinFast sincerely apologizes for the experience you had on the VF 8. The VinFast team will contact you as soon as possible to solve this problem.
It is very important safety feature. It helps to reduce blind spot when you make change lane. I hope next software update will fix it 🙏👍
This reply was modified 2 years, 1 month ago by
Tho2k.
Thanks Vinfast for quick response. They sent a tech to explain my problem and it took care the problem👍❤️
What was the solution? I ‘m having same problem
The setting wont save, every time you turn on the car, you need to turn on that feature again
I too facing same issue? it does’t turn ON while taking turns .. Is there any fix for this issue?
While taking turns? Hmmm
There’s a setting in Drive Aids that has to be on. If it’s on while at a stop or less than 9mph, camera will be on.
