Home › Forums › Discussions › VinFast Fan Running Even When Car is Off – Draining Battery! Any Fix?
  • VinFast Fan Running Even When Car is Off – Draining Battery! Any Fix?
    04/25/2025 at 13:41
    I’ve been dealing with a frustrating issue with my VinFast. The fan has been running non-stop even when the car is off, and it’s been going for two days straight. Each day, it’s draining about 30% of my battery.
    I reached out to the service center, and they told me to take the car to a dealer. However, my local dealer is overwhelmed and unable to schedule me due to resource shortages. Meanwhile, the fan keeps running, and I can’t just leave the car parked like this indefinitely.
    Does anyone have any insights into what might be causing this or a potential fix? Also, is this a safety risk? I asked the service center, but no one is giving me a clear answer.
    Appreciate any help or advice! Thanks.
  • Raj K
    05/12/2025 at 21:10
    Disconnect negative 12v battery and you have to remove a yellow 60 amp square fuse. I had the same issue and the service guy told me what to do. I think it was in the top row
    05/05/2025 at 14:56
    Id pull the negative terminal off the 12volt battery in the trunk for 5-10mins, than put it back on, that should clear out any issues. You will need a 10mm wrench.
  • Yossi Gordon
    04/30/2025 at 14:40
    Does the screen and radio turn off? I had things on my back seat, and the car refused to turn off, thinking somebody was sitting back there. I wonder if your car is just not turning off, and it’s running the AC the whole time your away.
