Home › Forums › Discussions › Strange loud noise after a full stop
03/06/2024 at 11:54Anyone here experienced this kind of loud noise? Its like a fog horn from a cruise ship. The noise will come intermittent. It happens specially when its raining or cold weather and when I am on a full stop and start to move slowly. It looks like the caliper pads stuck on the rotor disc. What do you think it is.
Here is the link I posted in Social Media. https://www.facebook.com/reel/1507114119847898
Call service they need to replace the rotors. That was a common issue on the CE. Once replaced it went away.
As the other commenter (Scott Davis) said in this post, this was an issue plaguing many of the City Editions. VF said it was fixed on the Standard Editions. The fix was replacing the actuator component of the rotor. My CE had the same noise when moving from a complete stop. They replaced my actuator 13K miles ago, and the noise was gone for good.
I am also experiencing the same issue. I noticed it happens early in the morning and also when it rains.
