Home Forums Discussions Sqeaky rear end and nonworking mirror and steering wheel controls
  • Sqeaky rear end and nonworking mirror and steering wheel controls
    10/17/2024 at 20:10
    Ive had my VF8 for almost two months now and have been having problems with rear end squeeking and creaking at low speeds. It sounds as if its metal bending. Also, my cars steering wheel and mirror adjustments dont work anymore.
    The suspension noises started after I got my car washed during the first week and its gotten worse since. Ive reported the issues to vinfast but they say to keep driving the car until my appointment on the 21st of October but its quite annoying and embarrasing that a new car would sound this horrible.
    Im not entirely trusting of the vinfast reps. Each time ive called they say to drive the car and when I inquire if its a known issue they say there have been very few reports of the suspension noises.
    Anyone else experiencing unusual suspension and squeeking noises from their VF8
    You must be logged in to participate.
    • Yes
    • No
    4
Page 1 of 2
  • Aida Fermin
    10/25/2024 at 15:42
    hi- how did VinFast fix this?
  • Troung Cao
    10/29/2024 at 15:51
    I have a humming noise from right rear. Car is currently with Vinfast to be looked at.
  • AARON HANSON
    11/02/2024 at 13:32
    Same with my 2023 VF8+ CE. When I first startup the rear squeaks and creaks at low speed. After I get going the sound does not return unless I turn off and back on the vehicle. I suspect it’s the parking break system. Software version is .16, I wonder if the .18 addresses this issue.
  • steven sanchez
    11/03/2024 at 20:53
    It only happens to me when turning right for a few seconds and goes away. Not a big deal to me at the end of the day as put zero down and only pay about $200 a month to lease my plus vf8 for 3 years. Some people have told me that this only happens with the 2023 Plus models but I dont care. I have had the car now for over 2 month and no serious issues and I really love this car.
    • Mike Tretola
      12/10/2024 at 18:59
      I get a similar sound when turning right at low speeds, but not all the time. I plan on taking it in to have them look at it. (2024 VF8 Plus – got it in Oct)
      • Bill White
        12/11/2024 at 10:18
        I have a 2024 VF8 Plus also that has a growling sound in step with the front car wheels when turning right at speeds below 5mph. It is not consistent, but it is more pronounced when it is colder than 50 degrees F. It is a short vibrating sound consistent with the front wheels turning. Sometimes I hear it when going straight, but never to the left. Took into Vinfast service and let them hear the sound I recorded, but they could not reproduce the sound. They put it on the lift and checked the front end. They could not identify any issues. The tech even road with me trying to reproduce sound. It started raining a bit after leaving the service center. It then made the sound after I came out of the store 15 minutes later and crawled out if a parking space turning right slowly. First instance from new was after a car wash. The other creaking body noise on a plus was already solved by the service center. See my other post for solution.
  • Bill White
    11/14/2024 at 10:12
    My service center solved the creaking and squeaking issue coming from the passenger rear door area. They dropped the headliner, removed the sunroof and sunroof frame. Then, they put felt where any metal contact between the sunroof frame and vehicle. No further squeaking or creaking which was happened constantly on turns and bumps that put pressure or twist on the frame causing a creak.
  • Michael Ross
    12/11/2024 at 05:52
    What was the resolution to your squeaky rear end?
    I’m concerned about mine as it “creaks” going over bumps and such.
    • Bill White
      12/11/2024 at 10:31
      See my post for my Vinfast service center resolution for squeak in rear of a VF8 Plus.
  • Derrick Tam
    12/22/2024 at 11:35
    I get the squeak too. I don’t even care anymore. This car is not good. I reported issues 5-6 times already. My car went into service 5-6 times and they just say updates are needed.
  • Minh Quan
    12/28/2024 at 07:09
    Experiencing rear squeaking at slow speed from a stop and faint clunk type noise upon slow take off from start.
  • Lou Scavo
    02/04/2025 at 09:00
    I got my VF8 in December 2024. I’ve had a few strange popup warnings and my drivers window would not go up. The last issue was the creeky groan sound at slow speeds. The car has been in the shop for about a week. The service manager said they reset the computer and hopefully corrects the strange warning popups. He also said the groan is a known issue coming from a mount on the springs. He said the parts are in and I should have it soon. I will let you all know. One question I have is that I do not see any gauge for the regenerative braking. I’ve seen in a couple of videos. Does anyone else have this gauge?
  • Rick Primiano
    02/13/2025 at 17:50
    I have had my VF8 for about 2 months and I notice that when going slowly over a speed bump there is a noticeable sound from the rear end. Sounds like a creaking noise as of the car were very old.
    I also noticed that I. The. Older weather when I make right hand turns there is definitely a noise which comes from the right rear of the car.
Page 1 of 2
