Home › Forums › Battery & Charging › Is it possible to charge Vinfast faster?
04/25/2025 at 13:42I own a VF8 plus and it takes more time for charging. How to DC fast charge it?
There are many factors Including the outside temp, the battery temp, how much current charge you have, etc! I always get over 100kw on DC3 chargers on both my VF8’s – I have a 50amp charger installed at home, wired directly into a 60 amp breaker – always get 48A/11.5kw – I also live in florida where its always warm!
A 100kw charger (LEVEL 3) will charger the car from 10% to 70% in an avg of 31 mins. – The battery max’s out at 150kw max charge. If you have a level 2 charger at home thats at least a 40amp, it should be more than enough to keep your car charged every night!
