Home › Forums › Battery & Charging › Charging stops before reaching target settings
  • Charging stops before reaching target settings
    06/12/2024 at 21:50
    I have weird charging issue. Once I charge, after few minutes its automatically stops charging saying reached the target specified range, but not. Says, Charging completed, please remove charging connector.
  • Adam Bennett
    10/17/2024 at 08:23
    I had to drop the amps on my mobile charge down to 19 to get it to run consistently. Any more than that it would quit and claim Charging Completed after a few minutes. I’m installing the permanent Home charger soon, hopefully that will fix the issue.
  • Tin Nguyen
    09/07/2024 at 15:37
    I have same problem after having software upgraded. Actually, sometimes it works, but most of the time, it stops after few minutes, no matter I adjust the limit amps. Please help.
